WARDOG
I am having nothing but problems trying to correct some wiring mistakes by P.O. on a Painless (modern version) Harness.
If someone here has a Painless harness I need info on the following:
FROM the turn signal switch harness in the column, there is a plastic 8-pin connector. Using the bump on the connector for reference, I need to know the colored wire - to pin locations on each side of the harness.
I have a new turn signal switch (from WH) with wire colors
Blue, Green, Green/Red, Yellow - Blue/White, Green/White, White/Blue, Orange
The colors going into the Painless Harness at the connector:
Blue/Yellow, Green/White, White/Blue, Green - Blue, Red/Black, Yellow/Black, Yellow
I had to switch two pins, and everything worked. I installed everything again then it started popping fuses in multiple locations on the fuse block.
I am ready to burn this thing to the ground and start fresh.
Any help, photos, diagrams would be appreciated.
