lonesouth said:
using the pertronix kit to replace the points, does it matter too much what distributor you use? would a stock work just as well as aftermarket?
In some ways yes, it matters. In others it doesn't.
Your Pertronix unit may not even fit in an aftermarket distributor body for one. For another, most if not all aftermarket units are going to come with their own trigger assemblies already installed. That's part of what you're paying for anyway. So if you want to use the Ignitor that you already spent money on, you may have to use a stock distributor.
High end distributors are built to closer tolerances and higher standards of consistency than a stock rebuilt or maybe even a new one. Even though a Ford distributor is a decent quality piece as delivered. Not to mention the very high cool factor of a beautifully machined piece of aluminum with all the fancy bells and whistles on it.
I would just use a new or rebuilt stock one anyway though. That way you have all new bushings or bearings for as precise an operation as you're going to get from a stocker, and have the Ignitor instead of points. Very big bang for the buck that way.
