jerks hahha.
Mlogan, that is a great link. However, can I use my current flexplate and the 99+ 4.2 torque converter? Or do I need a V8 TC for the 4r70w?
Oh man, that's one I'm not so sure I can answer (it's been a while since I did my swap). What comes to mind is that you need to use a flexplate that is for your engine and how it is balanced (internal/external, 28oz/50oz), from there you just need to make sure the tooth count is right. Not sure if it helps, but I think I used the stock flexplate on the back of my 5.8 (which bolted up to an E40D stock), and it was the right tooth count and bolted to the stock AOD TQ. Hopefully, some of the other guys can give you a better answer. Even if you can't find a stock flexplate that works, companies like B&M sell them. Generally, you want to use the stock TQ as the stall is pretty good for low end wheeling. Not sure if you joined, but I have a bunch of links to AOD swaps on
my Yahoo group for AOD's.
Here-borrowed this-"The integral bellhousing AOD requires a flexplate
with 164 teeth (approximately 14 1/4" diameter with an 11 7/16" torque converter bolt pattern)"-from
here.
