AOD Exhaust 2 to 1 FYI
idus25
St. Louis
Just received my Gearstar AOD for my 76. https://drive.google.com/file/d/1CWpBJKMBU5ZURwAmHmh0McgsibRGsMbu/view?usp=share_link It has full width axles and a 408 Stroker with Canton 351 extra capacity pan, which made need for all new exhaust routing. Fear (laziness) of the work that would be needed kept me from building it for a few weeks. So I bought $200 of bends and pipe and ended up only using $50 or so excluding the Magnaflow y-pipe (p/n 10732). Thought I explain mine to maybe help others.
Using JBA shorty headers (WH) came off drivers side with a 90. Came off a y-pipe with another 90. Coupled the 90's with a short straight. The angle off the down 90 is such that I can remove the rear oil pan plug (bottom drivers rear of pan). The Pass side was a simple 20 degree cut short.
I wrapped the pipe as they go up next to the AOD. I am using Tom's 700R4 Crossmember as well as Duff's Torque Tamer. The crossmember is below the bottom of the y-pipe and the exit comes out above the Tamer, so all I need is another straight pipe to reach the muffler.
hsach
Members Only
Nice work on the exhaust! More pics when you get it installed.
I was looking at Gearstar for a 4R70W, but haven't contacted them yet. I wasn't sure if they will add the Advanced Adapter I need for my D20. I have a 4R70W already, but getting one already rebuilt by Gearstar is very tempting. How long did it take to get the transmission?
idus25
idus25
St. Louis
3 months. I ordered the AA adapter from them. Just needed to put front drive gear from D20 on new output shaft when I got tranny.
