Astro Hydroboost Model Comparison
edge4
Gonzales, Texas
Just an FYI. I thought I would take a picture of two different year Astro/Safari hydroboost units for comparison to help board members look for the optimal setup if they go the Astro route.
The unit on the left is from a 2001 Astro. It mounts with an angled bracket downward, has a longer pedal arm, slightly different M/C clocking, and a viewing window of some sort. The Saginaw pumps seems to be identical with two return ports. The reserve canister has a large port on the bottom and smaller port on the side.
The 1995 Safari setup on the right had the shorter arm (which will need to be extended), flat mounting, same pump, and a reserve canister with both ports on the side.
The 95' has a straight M/C which can be incorporated, the 2001 M/C would be hard to adapt. Both will fit the popular 80' corvette M/C (found new for around 50.00)
Madgyver
Bronco Madman
That's the angled bracket I want!!!
Nice score..
Where is the hoses?
Stock hoses that came with the units can be used in the EB.
casadejohnson
Bronco Alchemist
If you want to see a pic of the earlier version installed ( Mines from a 91 Astro), check out my gallery. I used the Astro M/C and proportioning valve as well and have no rear wheel lock up problems. I Love it. I have mine mounted in the stock location with a Fuel injected 351W It's tight but it fits.
edge4
edge4
Gonzales, Texas
Mad,
I was about to throw the angled bracket away. It's yours if you want it.
No hoses. The yard these came out of, sends a runner to get your parts. They work on the cut and yank method. Hoses are extra. I'm using AN adapters and Aeroquip hose for all plumbing. Still wating on my all in one M/C from Classic Performance. Product introduction date has been moved out twice.
Edge
Madgyver
Bronco Madman
Edge,
I'll take it! Send it to me and I'll pay the shipping cost. It should fit in the small US postal box that cost only $3.85 to ship anywhere. I'll PM you with my address.
I've come across alot of hydroboost units in the yard but only one I got the angled bracket.
Thanks,
madgyver
Madgyver
Bronco Madman
That's an easy fix, Send it to me. I'll just run a bead on it....
Do you have the studs and nuts that go with the plate?
Send them also, if you don't need them. All the pieces should fit in the small US postal box.
Thanks,
madgyver
