Dave St
Before, anyone says "use the search", I have already, but I can't find an answer.
I am using a hydroboost from a '95 Astro, with the Astro master cylinder and proportioning block. The block has two ports for the brake lines. I believe one uses a 10mm fitting, the other a 13mm. I need to adapt the SAE brake line fitting over to the metric sizes, so I need an adapter to go from the standard 3/16 brake line to the metric sizes. I went to every hose, fitting, and auto store in town (about 4 hours of time!) and no one has anything that will work, so I am stuck with no brakes
Any ideas where I can get an adapter? I thought that NAPA sold something that would work,but the NAPA guys here are clueless. Please include part numbers if you have them. Is there any other solution I am not thinking of?
Thanks!
Thanks!
