Astro Van Hydroboost
Buddy's 70
Has anyone put an astro van hydroboost and mc on their EB?I have access to one that is nearly new and was wondering if someone has tried it before.At first glance the nitrogen canister may be in the way of the throttle linkage,but not sure.Any advise would be helpful,thanks.
Lebe
Phx
Yeah, the booster itself is rotated 180 degrees to clear Explorer plenum. I liked the Astro MC as it is alloy and won't rust and is made for front disc, rear drum. My setup. And are relatively cheap and available.
Works great when my PS pump is working.
jdcone
riverside, ca
What year does the AstroVan hydroboost come from? And what year and make does the power steering pump come from? I want to clarify a list I have made for junkyard items for the EB that I have kept up for everyone here.
Lebe
Phx
Probably half the Astrovans in the pick-apart have hydroboost. Mine fit fine straight of the firewall with an .125" plate for the mount (clears the Explorer upper plenum by .5" with 3" BL). But some come with an angle plate to angle it to the driver's side. I picked up one of those too but didn't use it.
Mine is a stock Explorer pump, rebuilt now three times, but it doesn't appear to be up to the task of hydroboost, PS box, ram assist, cooler and oversized dual return reservoir. Trying a smaller pulley this week. If that doesn't work I think I'm going to send it to Howe Steering so he can boost the volume. He claims its 1.8 gpm stock at idle (crawl) and he can boost to 3.5 gpm. But he also says that I may need to increase line sizes which is far more problematic.
This is probably more than you asked for.
B
Buddy's 70
Thanks guys!
toddz69
Lebe:
Stopped by Driven today and Randy says it appears the Lee-modified pump that I sent in for experimentation on your truck is working well so far. Certainly better than it has in the past. Hopefully you can get some driving time on it soon to see if it cures your ills.
Todd Z.
