Auto Steering Column Rebuild Kits
Dave K.
Does anyone have a source for rebuild parts for a power steering/auto column?
My Bronco like to hop in reverse when in park and the shifter does seem loosey goose. I understand there is a detent plate back there that gets worn and allows these inadvertent movements.
Thanks in advance for the help. Dave.
**Could use instructions on how to do the rebuild as well! Understand there is a procedure somewhere on the board.
D
Dave K.
Thanks, I was looking there earlier and didn't see it for some reason. I see they have the lock plate which should help. I'll check out the videos. Thanks Again.
Just watched the video, that explains a lot. Not a huge deal to gut it I guess, we'll see what I find.
5001craig
My father-in-law and I rebuilt mine and just could not get it right. I ordered a new aftermarket one from JBG after I thought he was going to throw it through a window. The new one has tilt but does not cancel one of the turn signals. I called the manufacturer (eyedidit) and they said they would send me the parts to correct it. Didn't work. Called them again and they said I could send it to them and they'd fix it. I need to do that.
I found out after I purchased the aftermarket column that there is a local shop that does this for a living. In hindsight I would have taken the new parts to him for the rebuild. But then I would not have had a tilt column and I really needed that.
Hey DaveK. I don't think we've ever put a full kit together, but pretty much most of the parts usually needed are readily available. Here's our page: http://www.wildhorses4x4.com/category/Bronco_Stock_Column_Parts
Think about a shift tube as well, as many of those crack over the years. Nice when you can take yours apart first, but for time saving, most want to have the parts handy before they pull theirs apart.
I can understand that, but for certain years it really helps to know just what you have.
What year is yours? If it's a '73, '74 or '75, I recommend either buying every part on that page(!) or at least giving yourself extra time and pulling it apart first. Ford tended to make Franken-columns during those three years (especially '74's!) so it really does help to plan ahead.
To that end as well, don't worry about returning something. If you buy a few extra parts to begin with just in case (like the three different bearing types for instance) you can return any unused parts you end up not needing.
Just a thought.
(after all that, I bet he has a '74!;))
D
Dave K.
Yep, it's a 74 Ranger....
Thanks for the link--don't see the lock plate for the shifter though in your listing and I think that's one of the main pieces I need given the foibles of the errant shifting.
The truck is laid up for the winter so I have time and will probably pull the whole assembly, take it apart and inspect/order accordingly.
Regards, Dave.
Faster Eddie
Seattle
I replaced that lock plate twice in 15 years, buggered around with that column forever and never could get all the gremlins out. Bought a rebuilt one from TBP and never looked back.
D
Dave K.
I will see how mine looks when I take it all apart. The rebuilt ones are pricey and to be honest these don't look that difficult so I'll give it a go and post pics here of what I find. First step is getting the damn horn button off--one of the clips seems stuck or something and it's keeping me from removing it!
Curious what gremlins you battled with?
gray gables
I need to do this to mine. How can I tell what year my column is. I have a 67 and I got the column out of a donor. But that was back in 94 and I can't remember what year the donor was.
