Auto swap t-case shifter problem
Teal68
Inlet Beach
As some of you know I'm swapping an auto into my wife's Bronco. I have a new problem now!
The bolt that goes thru the t-case adapter to attach the shifter won't fit. It's too big. I can't just switch to a smaller bolt because the shifter would be too sloppy since it rides on that bolt. I'm guessing drilling the t-case adapter hole bigger might be an option. Sucks I just installed it in the Bronco last weekend.
Am I having this problem because the 68 has a T-shifter, and all automatics require a J-shifter?????
Please help once again. :)
Thank you all,
Tyler
BRONCROB
WISNER LA.
If I can remember the bolt has a shoulder where the threads start,they are smaller than the shank.You may want to find a bolt that fits the threads and a bronze bushing from the hardware store to take up the slack or a factort size bolt.
Viperwolf1
electron whisperer
Autos don't require a J shift. You probably could drill out the hole if you can't find a bolt that fits.
Teal68
Teal68
Inlet Beach
Think I created enough room to drill it out. If that does not work I'll go the bushing route. I like the idea of using the bigger bolt though.
Teal68
Teal68
Inlet Beach
What a pain!!!!! It's drilled out and the shifter is mounted! Some bruises and a broken bit, but it's done.
Thanks for the suggestions,
Tyler
