auto transmission install help... Quick!!!
Tgirouard
San Diego
I am presently in the ninth inning of my 3 speed to c4 conversion.
I am trying to bolt up my auto tranny. I have lined it up and ready to put on the four bolts for the torque converter. I am confused because the bolts go right thru the holes on the fly wheel. Are there supposed to be washers that hold the the flywheel to the torque converter? I didn't get any with the transmission kit. The nuts should be correct. they are lucking nuts. I got them from a Ford dealer.
Thanks for any help
j.r.nice
Thanks for any help
there werent any washers on my AOD....just the locking nuts.
T
Tgirouard
San Diego
Did the bolts go thru the flywheeland tighten down on the torque converter? I am wondering what holds the two together? When the starter moves the flywheeel does the bolts catch and then move the torque converter?
Just want to make sure
wildbill
Old Bronco Guy
;D ;D ;D The 4 nuts that bolt it together are sholdered lock nuts. Just torque them down. Good luck :p :p :p Bill %) :p :cool:
T
Tgirouard
San Diego
should the shoulders on the nuts tighten down on the flywheel? Mine are small enough to go thru the holes in the flywheel and tighten to the torque converter.
ken75ranger
Troy, NY
Either the nuts are too small or the holes in the flexplate are too big. The holes shouldn't be much larger than the stud going through.
T
Tgirouard
San Diego
It is a flexplate. It came with the transmission and I checked the part number and it was for a bronco.
bsaunder
I would guess the holes you have it lined up to are the wrong holes - the bolt going through the hole should fill the entire hole making any nut unable to pass through the hole. If there is slop in the holes around the bolts then there is something amiss.
T
Tgirouard
San Diego
Just as you suspected Bsaunder I had it lined up to the wrong holes. Dooooohhhh! It was a pain in the ass to change.
