Auto meter Transmission temp gauge install
Banjer Picker
Anybody running the autometer transmission temperature gauge? My wife's rig is running a C4 with a remote electric fluid cooler. Trying to determine how/where to tie into the system. Any input or write ups would be great! The ones that came with it aren't very helpful.
Brandon
Tiko433
I know just enough to be dangerous
Bolivia, North Carolina
I don't have a Auto Meter but I have a Glowshift I put the temp probe in the pan . I figured it would give a good operating temperature
gr8scott
I'm running one. The best place for the temp sender is the trans pan. If that's not an option for you, tie into the trans 'out' line before it gets to the cooler. You'll need a temp sender manifold like this:
https://www.summitracing.com/parts/atm-2286/
I just used 3/8" hose barbs. You'll need to run a ground wire from sender body to ground. i used a small hose clamp to secure the ground wire to the sending unit. I know it sounds ghetto, but it works.
As far as the instructions for the gauge, they're pretty straight forward.
ET
Dallas, TX
I mounted my sender like how gr8scott discribed. Only difference is I used hose T with 1/8" port.
Eugene
Banjer Picker
Banjer Picker
For the guys running the sensor in the pan, did u have to weld in a bung for it?
sanndmann3
I also have the Autometer trans temp gauge. I used 2 senders (coming out of trans before cooler and after cooler goingback in). Hooked the sender wires up to a toggle switch that then goes to the gauge. you can buy extra senders at Summit if so inclined... The install is straight forward and as others have described...
gr8scott
I mounted my sender like how gr8scott described. Only difference is I used hose T with 1/8" port.
Eugene
That's probably a much less expensive option.
I also have the Autometer trans temp gauge. I used 2 senders (coming out of trans before cooler and after cooler going back in).
I did the same thing. One gauge, two sensors using a SPDT toggle switch. I found that I only monitored the 'out' temp and rarely looked at at 'in' temp.
I decided one day that I needed a 'second opinion' on my coolant temp because my factory gauge read so low , so I moved the 'in' sensor to my thermostat housing.
Factory gauge reads 160-170, AutoMeter reads 180-195. I know its based on location and the fact that the sender for the factory gauge may not be the correct one.
That being said, I do have a sensor manifold that's not being used if the OP wants to make me an offer. They were $20 cheaper when I bought mine.
The industry standard for measuring transmission temperature is pan temp.
If you watch the temp going out to the cooler you will see it spike every time you work the convertor. Doesn't show what the transmission temperature really is, it just shows how much heat is coming out of the convertor.
The return line off the convertor is probably the worst spot. If you get a flow restriction in the cooler line the fluid flow will drop. Fluid will spend plenty of time in the cooler and come out nice and cold, what little that dribbles through the cooler. In the mean time what is in the transmission boils away from lack of cooler flow. (yes that can happen, debris clog, accidently pinched line, that kind of stuff.
If the cooler out temp goes up, you probably picked up a shopping bag in front of the cooler.
ntsqd
heratic car camper
Upper SoKA
I'll second (third, eighth?) putting it in the pan is the best place.
If you monitor the pan temperature then you know how hot the fluid about to be pumped into the trans to cool and lubricate it is.
If you monitor the cooler out line then you only know how hard you're working the fluid.
The fluid is the consumable, not the trans. Put it in the pan.
I take a steel (not cast) pipe coupler and cut it in half. Figure out where it has to go to clear internal and external things and weld it there. Then I use a center finder to center punch the pan at the center of the bung, and drill a small pilot hole. Then I use a Uni-bit stepped drill to drill the hole size needed from the inside of the pan.
Note that most senders need to ground thru their threads. Teflon tape is not the right answer. I use either pipe dope or Hylomar in the threads.
BronCowie
Old Timer
Vancouver, WA
I temp'd in an auto meter sensor on the supply line to the cooler a few years ago just to get an idea what's going on with my aging C4. Finally got around to getting the tranny rebuilt and they are moving it to the pan for me. :-*
67686977
Liberal\Claremore
I mounted mine in the pan. I have an aftermarket aluminum pan that is thick enough that I drilled and tapped to install the sensor.
JWMcCrary
Brandon, I installed a B&M pan and tapped it for the sensor (no welding). Running an Autometer gauge. Has worked fine for over 10 years. In a couple weeks you can take a look ;D
The only time mine heats up is for extended low gear crawling with more than just above idle throttle. Stop for a few minutes or get a higher gear and it will ease back down. I doubt you would know that without the gauge so I'm convinced if you pay attention to it and adjust for it then it helps the trans.
