RajinCajun
Does anyone here use a PTO winch with an Auto? I am about to put a C-4 in my Bronco, and I want to retain the PTO..??
Autos have an interesting habit. Put them in nuetral and they want to go forward. Even without the clutches engaged there is engough drag inside one to spin tires with a fair amount of force even in nuetral.RajinCajun said:Actually thinking about a hand brake inside the cab I could lock and hold the pto shaft while the auto is idling in neutral to keep it from moving...
I know normally as soon as the clutch is pushed in with the man the winch stops instantly...so with the auto it should do the same when put into neutral.
I try not to use the winch by my self at all...that thing would not stop until it pulled the bumper in, and destroyed the radiator and locked up the motor...LOL!!
If you add super low gears though the torque convertor will try to overtake the resistance behind it. Ask anyone that runs an automatic and super low gearing and they will tell you that when it is shifted in low low range that it takes a good set of brakes to keep it from going anywhere even at an idle. I'm guessing that the PTO gearing will be even lower than the low low gears we are running which will mean it will be even harder to keep it from sucking the line in. I don't think it spooling back out will be an issue while it is gear.md_lucky_13 said:I was curious about the transmission torque converter when I read this..
I have never used a PTO and an Auto, so this is entirely speculation.. But, I picture the stall (torque) converter not allowing the PTO to start pulling and engauging until you reach an engine speed that allows the torque converter to engauge...
Much like if you were to have both front tires on a big rock ledge. Depending on gearing and stall speed, you might still be in gear but not going anywhere..
The only other description I have would be a simple stop sign. The brakes are enough to over-come the stall converter and keep you in one spot, even with the transmission in gear.
You might have a very delicate balance between the line pulling, the line stopping, and the line just plain free-spooling back out from lack of force in the torque converter...
In other words, the brake might be the least of the concerns.. I agree: either electric or hydraulic for me in an auto.![]()
