aux. fuse panel
1970WagonKY
Winchester, KY
I just bought anone wire 6 fuse panel. I am going to use it to power my cd, gauges, off road light, etc. What is the best way to hook this up?
I am thinking of just a heavy duty toggle switch from the battery to the panel. I would prefer a wire connected to the key, but don't know where i could/should do this...
SaddleUp
Vancouver, WA
I completely replaced the glass fuse box in mine and put it on the tranny tunnel up under the dash. I ran two boxes similar to the one you are getting. One runs items that need power all of the time (stereo clock, electric fan, CB, lighter, etc.), the other is keyed for items like guage lights, radio power, wipers, etc. If you feel comfortable with rewiring then that is what I would do. There are wiring diagrams available for the EB that can be used to assist in doing the rewiring. If you don't want to go that route then I would find the ignition supply wire going into the current fuse box and tie into that. Otherwise you will need to go back and be sure everything is shut down every time you shut it off.
Nevermind on shutting everything down. A master toggle would mean just one switch. If you do that I would run it through a relay to avoid overloading the switch.
TonyPDX
The small bolt comming out of the back of the ignition switch is the accesory circut I belive. If you are going to hook up high current accessoys, like off road lights, to it just use the ignition switch power to trigger a realy that supplies power to the aux fuse pannel straight from the battery. Watch your amps as big off road lights can draw near 30amps and that is what most relays are rated for, so you may need to find a 50+amp relay and 10 AWG or larger wire.
Watts x Volts = Amps
Tony
SaddleUp
Vancouver, WA
I would run the lights directly off a relay from the battery on their own fuse that is isolated from the fuse box. I have a fuse box up under the hood where the headlights (hi & low beam), off road lights and fan are all run on their own fuse and relay. The switches in the dash simply operate the relays.
donks&broncs
The Fort,CO
I set up my 4runner with the relay powered triggered from the acc on my ignition. I didn't like everything coming on when I turned the key on and then off when I actually started the truck, then back on again so I ran an b contact relay (no power shut, power open) off the low oil pressure warning light. This way, the accessories will only be on if the motor is actually running and won't turn on and off everytime I start. It also serves as a little extra warning if the oil pressure goes low.
74bronc
I have a 12 circuit Marine aux fuse panel that I powered off of a switched 12V relay. it works fantastic. You can't see much in the picture of how it is hooked up, but wiring a relay is simple.
