AX15 Clutch replacement
Tiko433
I know just enough to be dangerous
Bolivia, North Carolina
Can someone help me with what clutch part number I need. As far as I can tell I need a 10 spline 11” But I have read some threads that a Chevy disk was used. I’m not sure which one to order
Tiko433
Tiko433
I found the CenterForce part number on WildHorses The duel friction clutch is DF700000. I ordered it from them
rguest3
WH has been a great source for the AX-15 Swap. They have everything you need.
Flywheel - 280z or 50oz.
Centerforce and Luck Clutch Disc and Plates.
Also Complete kits if you need everything.
