AX15 Transmission Questions
EB70
One of my buddies is cleaning out his Jeep parts collection and there are a few 5-speed AX15s.
As I understand it, I can use most any Jeep based AX15 from behind a 4.0 from the late 80's until about 2000.
These are from Cherokees. One has an internal slave, and one has an external slave.
It looks like A/A has a kit for install for reasonable.
Is there any specific year etc. that I should be looking for? Other concerns with them as far as mileage and when they go bad etc? I will likely rebuild it, but I haven't decided for sure yet until I know what they are.
Other thoughts and opinions on the AX15 swap? It will be used for mainly DD use and some wheeling in the winter.
broncodriver99
Glen Allen, VA
The diameter of the input shaft snout changed in the later years. Went from 0.59" IIRC to .75" The trans with the internal slave will have the smaller snout. The best and easiest to swap is the later trans with the external slave and larger diameter snout.
zimm
N. Weymouth, MA
I installed an AX15 out of a 98 cherokee. Its awesome. Has the .75" pilot shaft and external slave, although I just ran the stock bronco clutch set up. I also used a bronze pilot bushing instead of bearing. I would not have used the smaller diameter pilot shaft but that might be just me. The adapters are available through advanced adapters, other places too (summit?). I think the transfer case adapter is the same as the NV3550, the crossmember is the same, the engine adapter is specific to the ax15.
John Marinan
Durango CO.
Novak conversions sell kits for the bronco, and RSG sells brand new AX 15s. Both of these vendors know these transmissions well.
E
EB70
Roughly what is the going rate on an AX15? Used of course.
broncnaz
Roughly the same price as a NV3550 a lot of jeep guys are going to it. Due to the lack of NV3550's and parts. The AX is still made for some different applications. So parts are availible so thats a plus.
E
EB70
OK. I think I'll get the transmission or at least look into it.
zimm
N. Weymouth, MA
Avg on craigslist around here is about $450-500 for a "good working" trans. If lucky you might be able to score one for $200-ish.
