There are no outer seals in the tubes on a 44. Only the 30's got those, and not all EB 30's had those either I don't think?
So yeah, grit and gunk do build up in there.
If you ever leak gear oil, it's the INNER axle seals that are the culprit. They're all the way in the bottom of the tubes and you need to pull the diff to change them.
Which also means you have to be extra careful pulling and replacing the axles when they get down near the end of the tube. Be gentle and rotate the axle shaft when inserting past the seal.
There are diagrams hereabouts regarding the outer seals and bushings/slingers/shims, but here's the basic rundown.
From the spindle inward:
1. the small open-ended seal that just fits into the back of the spindle bearing. It's not a press-fit or anything. Just barely held in there by it's own pressure. I always mount them with the open channel towards the bearing, but others have done it the other way for years without any trouble either.
1a. Your '72 "might" have the recess in the back of the spindle for the larger spindle seal as well. If so, you can use it as well (our part #8840). If not, not to worry. Many of us don't have that and things work just fine. My '71 should have one, but I've never used one as they don't typically come in the standard kits.
2. there is a thrust-washer/shim that goes around the axle shaft itself. The beveled edge faces inward toward the u-joint to better fit the radius of the machined portion of the shaft.
3. the "bellows" seal is the larger of the two and it's wider side slides over the machined portion of the shaft too, just around the area where the thrust-washer is. The "flap" side, or whatever you want to call it, faces the spindle.
Your stock axles would have had "slingers" that are thin sheet-metal pieces that are semi-press fitted to the outer axle shafts near the u-joint. These are not typically a "service" part, but if damaged they can be replaced.
Most aftermarket shafts don't even have them.
Since you're in that area anyway, now's the time to clean and re-pack the spindle bearing itself. Unless you're replacing it that is. Then it's clean already, but can still benefit from a little extra forced-in-by-hand grease. The excess will just spit out the other end of the spindle where you can use it for the bearings and hub.
Also, unless you know for a fact that your u-joints have been replaced in the recent past, it's not a bad idea to do them now too. If you haven't already.
Hope that helps.
There are pictures hereabouts and on some of the vendor's websites. I don't think ours blows up large enough, but let me go check anyway...
This page has the seals:
http://www.wildhorses4x4.com/category/s?keyword=spindle+seal but not the writeup and exploded view.
Here's the exploded view, but as said, it's not that large. It does have all the pieces we're talking about however:
http://www.wildhorses4x4.com/category/bronco_Dana44
