kmckee3434
- Apr 4, 2026
- 2
Hey, I’m looking for some recommendations on what I might be doing wrong. I’m doing a rear disc brake conversion with a kit from Tom’s Off Road. I am at the step where you re-insert the axle shafts. I was able to get the passenger side shaft back in with no issues, but the drivers side shaft is getting stopped from fully inserting about an inch before it should. I’m not sure if it’s getting stuck up on the bearing or in the differential at the gears. When I have it in as far as I can get it, it is locked up and does not spin. I’ve tried tapping it in with a rubber mallet with no luck. I’ve tried taking the shaft out and rotating it to different positions, and it still gets stopped at the same spot. Not really sure where to go from here. Any advice on what I could be missing would be appreciated.
https://flic.kr/p/2s5NUSK
https://flic.kr/p/2s5H5Vf
