axle shaft upgrade
AU Bronco
Madison, AL
I am looking to upgrade my front 44 axle shafts to some chromoly shaft and beefier ujoints. I want to get yall's opinion on who makes the best shafts and joints for the money. Also are the shafts the same for disc and drum setups. The reason i ask is i have a 75 bronco but have a later model front axle with discs.
Thank you
Kyle
ken75ranger
Troy, NY
Tell us more aobut your setup. What size tries and what type of wheeling?
One thing I noticed is one of the very respectable owners of Alloy USA jumped ship. They have a good product but their future is in doubt. ?:?
AU Bronco
AU Bronco
Madison, AL
My bad, im running 36 tsl sx, 4.88s welded front, spool rear, mostly rock and some trail riding, (trail ride usually after i break), and i usually air down to about 8 psi. 302 .030 over performer intake and 670 ta.
ET
Dallas, TX
I run moser from BCB w/ CTM joints. I have 36" swampers. It held great at the roundup last year but I can't tell you if it's the best.
Edit: It's a tight fit w/ the drum brake knuckle d44. Not issue w/ f150/bb knuckles.
Eugene
evil69
fawkin classy
Athens, GA
NOT YOUKAN'TS. Unless you really like replacing front shafts and sending them in for replacement. The Super Joints are fine and a pretty good deal.
ken75ranger
Troy, NY
That combo sounds like your going to break most front axle shafts. The 9 inch should hold up fairly well. I'd look at Superior Evolutions series and some CTM's.
I would seriously look at going to a d60 front axle or a selectable locker unless you like replacing shafts. That welded front is doing you no favors. Try not to turn hard under throttle!;)
AU Bronco
AU Bronco
Madison, AL
I got a price of 565$ shipped for yukon axles and joints from a guy on pirate. But wildhorses has a deal right now on warn shafts and what they call gold joints (i think they are super joints) for 452$ or 492$ shipped. How to the warn shafts stack up?
ken75ranger
Troy, NY
I'd go with the warn shafts over the yukons.
