The set up's that are on top of the spring don't do sh*t. You need something that attaches to the bottom of the axle. Notice in the video how the axle is trying to walk out from under the axle. That's the movement you need to stop. Think of the position of the leaf mounting to the axle as a hinge. By creating triangulation between these three points, leaf to axle, bottom of axle, and front leaf to frame connection, you can control the wrap. You want your front mount to be in the same area as the CV and front leaf bushing to reduce bind. You also want the front location to be able to pivot forward and backward as the axle compresses and drops out or it will bind and reduce articulation.
