I just bought a set of 15x8 soft 8 wheels for turning into beadlocks. I was a little worried about the 4" back spacing when I bought them. Turns out I was right. The outer rim/bead is flush with the outer part of the front hub and barely clears the heim joint on the steering arm.
I would like a wider stance than what these give. I know the beadlocks will add about 1", but that isn't much. Now I'm not saying that I want the wheels way outside the side of the body, but a little would be nice. I was talking to my brother and he said that the PO of his bronco bought some "reverse" spoke wheels. I guess the rim is flipped inside out then welded to the center... I guess it is a cheap beadlock??? ...thats what he says, not me. Anyway his wheels have a nice stance, a little wider. What wheels do you all suggest for getting a wider stance? I cant change the rim from a 15", but I can send these back.
...should I cut my centers out, push them out, and reweld them? Or is that way too much work for the return?
pics???
thanks
Ryan
pics???
thanks
Ryan
