jetsg4
I have been running my truck the same way it was when i got it, without the vacuum advance hooked up. When i hooked it up before, it would backfire when i let off the throttle.
Well, i finally got around to putting the timing light to it. The timing was set around 22, i adjusted it to 12 and hooked the vacuum advance back up. Now it backfires more. Read some posts to adjust down to the 6-8 range and try it again, as I did. Still backfires.
So, where to now? New vacuum advance? New distributor? Turn it back up and leave the advance off??
