Backup lamp switch
Mark
Bronco Klutz
NW Indiana
I suspect I have a bad backup lamp switch.
Anyway I need to find it, the wiring diagram below shows it, is it in my column?
IowaMike
Manual or auto? If manual, it's on the column under the hood When you put the shifter in reverse, you can see where the shift rod connection contacts the switch (if it's there).
IowaMike
Sorry, can't help there other than it should be down by the linkage on the left side of the tranny.
Flash69
Southwest Va
I was told the other day that it is in the neutral safety switch. I need to find my sons. His backups aint working.
RIbronco
Costa Mesa, CA
On a C4 the neutral safety/reverse light switch is located on the transmisson case where the shift linkage is attached. The gear selector shaft goes through the lower part of the switch, and the switch body is held on with two screws. Oh, and it's the only thing on the transmission that has wires running to it.
Mr Joe
Yep...and it looks like this
Mr Joe
Flash69 said:
So if your backup switch screws up on an automatic it cost some bucks to fix huh.
Not too bad.... I bought a Standard switch for $49. It actually had the Ford logo stamped on it. Beat paying over $100 for a NOS switch.
RIbronco
Costa Mesa, CA
That's about what I paid.
It's easy to install as well, just the three fasteners hold it in place. To adjust it properly, set the trans and column to neutral and inert a #43 drill bit all the way through the small hole just above the larger hole (pictured a few posts up). Then tighten the mounting screws.
trophybass
Plant City, Florida
Where did you guys find a NSS for $49.00. I ended up at ford and spent $100.00
trophybass
Plant City, Florida
that sucks, the only other places i fount it was from toms and WH and by the time it shipped to me it was like 95.00. Oh well. Thanks for the tip though. It looks like theve got some good stuff there.
Mr Joe
I'm very happy with Rock Auto.. I've used them for a couple years.
