Backup light switch pic needed.
Bronco Paul
Hey, can anyone post a picture of the stock manual transmission backup light switch with the reverse lever making contact with it?
Thanks,
Paul.
bteutsch
You just adjust the bracket to where the switch is being depressed by the shift linkage and tighten down the worm clamp. I'll try and get a pic when I get home.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Exactly. Put the Bronco in reverse when it's just parked, loosen the clamp holding the switch and bracket to the column and adjust to the correct place to come on when the shift arm is in the reverse position.
Bronco Paul
Bronco Paul
Appreciate it guys! Put the switch in, wired it up,adjusted it...and now I can see when I back up at night! Ah...the little things I tell ya!
