Went to rebuild the rear end after my pinion started jerking around alot... After opening it up I found that the half of the rear pinion bearing casing was not even there! What was left of the bearing race was the only thing holding the back side of the pinion gear. The gear teeth were not chipped but the bearing had spun on the pinion shaft wearing it pretty good. I suppose I will be at the junkyards next week.
