I have a 73 with a 302 and 1g alternator with a voltage regulator on the firewall. My battery is not charging so I took it to the parts store they said it was bad and gave me a new one. 2 weeks later same problem when I check battery voltage at rest it reads 11.8 and with engine on it reads the same also the same when the engine is given gas. It sounds like the alternator to me even though it is only a year or so old; could it be the voltage regulator if so is there a way to test between the two? Thanks in advance
