guidoverduci
Here's the full story... I decided to put a lift kit on myself. I'm not a pro at this stuff, but figured I could swear my way through putting on the lift. I've finished the rear, decided to fire it up... First, I switched the ign to on to prime the pump. It came on, but stopped after about 5-10 secs. It usually stays on the whole time. I then started it up and let it run. I gave it gas to open up the choke, then.. it died. I started back up, ran for a sec, then died. I noticed now the fuel pump doesn't come on, when ignition is switched on. It's a holley red electric pump with a carb setup. I also noticed the aux fuel pump doesn't come on either, but I can't be certain it was working before because I never switched to that tank till now. I'm not sure what I did while lifting it up, but it worked before I put the rear together. Perhaps some relay, or something electrical obviously... but I know NOTHING about electrical. I've got a cheap multimeter from Harbor Freight, but I"m not even sure how to use the thing... Any ideas?
