Ball joint torque?
sellers69
Durango, Colorado
I just torqued my upper and lower ball joints down, 100 on the uppers and 70 on the lower, like the specs I have in front of me say. Now my knuckles will not budge is this what I am looking for? This just seems to be to tight, like a sterring box that has to push big tires isnt stressed enough... The ball joints are brand new, and its a Dana 44...
On a second note I rented a ball joint press from AutoZone the press was made by OEM, I just want to say that this tool was the most poorly engineered and designed piece I have ever used...
cracker
Pueblo, Colorado
They will be stiff for a while, until they wear a little. That is the way it is supposed to be. You cannot overtighten the joints IMO. I really crank on them, especially the lower ones. They always seem to work loose on my sweet daily church vehicle...... ;)
crawln68
I'm going through this very thing right now too. I tightened the lower nut by hand, then torqued the upper sleeve to 40 ft/lbs, then torqued the lower nut to 100 ft/lbs and then torqued the upper nut to 100 ft/lbs. The end result is I have about 60 lbs of pressure pull in order to move the knuckle. I read that 26 lbs of pull is the max that you want. I have removed them and reinstalled them several times with the same result. Is 40 ft/lbs too much on the upper sleeve? Not trying to highjack your thread, I hope this leads to help for both us. Thanks.
dpmerrill
Springville, UT
Your torque's sound about right, but according to the shop manual, you want to do it in a different order.
With the top adjuster sleeve loose, tighten the lower ball joint to 70-90 lbs.
Then tighten the adjuster sleeve to 40 lbs.
Then the top castle nut to 100 lbs.
If your tie rods or drag link are disconnected, it should make the knuckles fairly stiff to turn. I think someone once said it could take as much as about 20 lbs of pull to move them (like you said). Try the different order and see how things turn out.
dpmerrill
Springville, UT
sellers69 said:
What are you refering to the adjuster sleve?
It is the small sleeve in the axle yoke that the top ball-joint sits in. It is threaded into the yoke using a spanner socket.
It's main job is to make sure the upper and lower ball-joints are sharing the load equally. If it is too tight or loose one of the ball joints could be under more compression, causing the knuckles to be harder to turn...
