CopperRanger
- Sep 26, 2007
- 1,796
I'm in the middle of replacing my ball joints. I have them pressed into the knuckle. The knuckle is back in the axle and the lower ball joint torqued to 70lbs. Here's where I am having a problem. When I try to torque the sleeve, the ball joint just spins. How do you keep the ball joint from spinning so I can get it torqued properly. Thanks
