Ball Joint
EricLar80
Hi Everyone,
I am wondering what the recommendation is - with the ball joints on the front knuckles - if they are easy to move but have no slop, should they be changed? If I flip the knuckle over, the top top ball joints will fall to one side or the other easily, but that's about it; no rattle.
I am usually in the camp of 'may as well replace if you are in there', but thought I would ask before spending the money unnecessarily.
Thanks!
blubuckaroo
Grease Monkey
Ridgefield WA
Ball joints on a solid front axle can last a long time, but if they're that loose, and you're into it, now's the time.
If you're doing it yourself, the outer "jam nut" can be really tough to break looke. It just laughed at the spanner I bought from one of our vendors. It just broke the fingers right off. I was able to get a "real tool" from NAPA.
E
EricLar80
I got the knuckle off, as well as the nut in the top. Luckily I used a lot of anti siege last time I was in there...
