Banjer Picker
- Sep 25, 2006
- 1,405
Flamethrower
Great! So that I am clear. If I run the 40011 or the 40111 I can remove the ballast resistor from that circuit all together?
According to Pertronix, you can use their 1.5ohm coil with the full 12v (no resistor) if using an Ignitor I on a V8 engine.
If the same setup on a 6-cylinder engine, you'd want to keep the resistor, or go to a 3.0 ohm version
This is the one we sell for that: https://www.wildhorses4x4.com/product/Flame_Thrower_Coil_Black/Bronco_Performance_Ignition
That is their #40011 coil, but they also have an epoxy-filled version #40111 for higher heat and vibration resistance. They recommend those for harsh environments like air-cooled engines or hard running off-road.
It's the one I've used in both the Corvair turbo and Bronco in the past (prior to switching over to computer controlled stuff).
If you prefer to use something from MSD or Mallory or other, you should verify the same characteristics and recommendations for their 1.5 ohm coils. Just to be sure they abide by the same parameters.
