Basic EFI question.
boltwebster
I just purchased a 1973 bronco. I'm planning on a complete restoration. I'm sorry for the newbie question. I have looked and looked on the forums and can't find the answer. Will I need to purchase a new engine to add multi-port fuel injection. I see that you can get a 5.0L manifold from an mustang or crown vic, however, will that bolt to the 302 that I have or will I need a different engine. I know I will need fuel pump, rails, wiring harness, etc.
Thanks in advance...
Matt
Bronco73
Cape Coral, FL
Just make sure you buy the correct intake gaskets. If I recall correctly ford change the coolant port on the end of the heads and I think if you use an older gasket on a newer engine it will leak coolant. Just can't remember if the same applies the other way or not.
Terkish
it dose. don't ask how i know. ;D
