basic questions
Basically, “yes.”
-or-
“It will work but you need to do some work first.”
And top it off,
“That is the way it is unless you upgrade.”
That should answer most of you questions. If it doesn’t then use this
“That will take way more work then it is worth and no matter what it will never work right.”
What question do you want me to attach one of these answers to?
mudstud
Bronco Bonehead
Excel
Which way did he go George? Which way did he go?
The Abominable Snowman
Looney Toons
commonlaw
Seattle
I recommend puting gasoline in the gas tank and oil in the engine rather than vice versa. That should take care of it.
ghost66
I think if you look at it from a different angle you'll find that it's not a 710 cap but an OIL cap, I hope this helps!
danny
the answer is yes, It will definetly be worth it when your finished.Just tell her your going to work,then go out and work on your bronco instead.
ha ha ,worked for me for a while ,till i got caught.
Still worth it.
