bauman controller help?
Nickm1024cobra
Chicago Burbs
I've got a bauman controller and loaded a file CHUMZIE sent me. Good file that got me on the road. Im learning to use the software but curious if anyone else has a file they can send me so i can get an idea of your shift settings at low to mid throttle. I feel like my 4r70w either short shifts 2500rpms at low to mid throttle or way high at full throttle. Like it to wind out a little more when not going balls to the wall ;D
Like to see your table if you have one. Thanks!
With the laptop sitting on the seat go for a drive. Take note of the TPS voltage where you want the shifts to come in a bit later. Just reshape the slope of the curve around the TPS voltages you noted above. From a completely generic file I had 90% of the shifting dialed in after about a half dozen test drives in a single day. The rest were just subtle tweaks after several days of driving or a few "lets try this" moments. Things like setting the 1-2 shift point to 0 MPH for the first ~10% of the throttle, that was great for idle creep at traffic lights or trails in 4LO. Another was 3rd gear no matter what throttle, for the chassis dyno.
As long as you got a fairly good starting point the rest is just personal fine tuning. No need to go and pick up a completely different file and start from scratch.
EricLar80
Make sure you set he base and full throttle voltage correctly before you do any test drives. I had not set mine originally, and it caused it to shift at funny times. Each engine up will be different, so you need to take note of each one with the engine off and set those parameters in the settings. Once you do that, I bet one of the two programs you have will work very well almost as-is.
Also make sure all the other setting are in there correctly as well. You can find them under 'view', then 'configure system settings'. Check all the tabs for correctness, but the one for full throttle is under the 'throttle position sensor' tab.
Eric
If you are getting different voltages at the TPS at every start up you are probably having a grounding issue. That is the controllers ground isn't on the same playing field as the TPS ground. If the TPS idle voltage changes with turning the headlights on and off that is a huge sign that you have a dirty ground issue. I had one that would push about half a volt difference, which was enough for the O2 sensors to always read lean and the engine to run stupid rich. Only at night with the headlights on. That was when I learned that all grounds are not created equal.
EricLar80
No, I don't have that. I am saying that one vehicle to another will have different base and max voltage readings and he should adjust accordingly for his (since it is set up with my settings).
I originally did not set mine, and it thought mid throttle was max throttle and would downshift accordingly. Took a few trips around the block to figure out why it was so downshift happy.
Eric
