Baumann Controller mounting location
englewoodcowboy
Lick Creek Restorations
99.9% of the public do not want to do anything except drive their car and operate their phone while doing so. Probably 85% of that group wouldn't know or care about the technical aspects of what the Baumann can do and that's why car manufacturers don't offer something like this to the public...besides the fact that the public would probably destroy the trans by changing the parameters.
This is precisely why they make them the way they do, it fills the majority of the needs and keeps prices reasonable. I have seen several clever installations like in Paul Perry's bronco and a few others that have fabricated a mount to hide the wires etc. and have it in view for constant monitoring or manipulation. This is part of the hobby and personal customization so we don't all have the exact same vehicle...
Bferrari
I stuck mine in the glovebox.
nvrstuk
PNW
There is no way there was much if any thought into the physical design of the controller as being user friendly. Not at all, not just my opinion either.
The original unit's were pretty much set and forget...if you wanted to tune, you could did it out of the wires nest under the dash, make your adjustments and stuff it back up when done.
With the newer units, like the new Quick4 and Quick6 controllers, they are designed to be used MUCH more frequently for tuning, changing tunes for different terrains, adjusting for low range 4 wheel drive applications, etc.
IF you are designing your shiftware to be used, you SHOULD design into it - accessability for the user. No way should you have to take up appr 1/2 of your glove box space to mount the controller because of the obvious poor user-unfriendly mounting options...
Having to literally "dig it out" from under your dash or from the bottom of your console is ridiculous...or have to take up 7" of horizontal space on your dash because wires stick out of 3 sides of the controller.
For about $20 extra per controller I'll bet US Shift could change the physical dimensions of the unit so the wires wounldn't make it darn near impossible to mount it "cleanly" and without having it take up so much space. The problem is this: Why make it such a big problem to easily mount, without taking up so much space, ... when it doesn't have to be? Not for how much they cost.
When the cost for a Quick6 controller is $1300 and then not having a simple clean way to mount it.... makes you look at other options on the market... but there really aren't any...
