BC Broncos 25th anniversary #22
Cactus killer
This ingenious new door shim kit makes it much easier to adjust your doors, by allowing you to just loosen the hinge bolts enough to slip the proper shim in from the outside. Standard shims require you to completely remove the bolts to install a door shim, increasing the possibility of paint damage. Because these are made out of stainless steel you can be sure you will not end up with rust lines on your new paint. There is more metal and more cutting so these are more expensive but they are way easier to install saving you lots of time. We sell these in pairs and offer them in three thicknesses, if you have a few Broncos or are a builder, ask about our builder packs.
63-00654 18Ga
63-00655 16Ga
63-00656 10Ga
https://bcbroncos.com/shop/25th-anniversary-parts-for-2021/63-00654/
