tatersalad
- Jan 17, 2009
- 1,067
I installed the BC EFI tank when I converted to EFI a year and a half ago, since then my fuel gauge shows full when full and then starts dropping when I have burned approximately half a tank of fuel. it will continue to drop until empty which will occur on the gauge at the half full position. I replaced the IVR in 2000 when I rewired with a Centech kit. From what I have read the BC sending unit is a new style linear unit which is why the gauge shows wrong but most posts have there gauges doing the opposite of mine which show full at the 1/2 full mark. I realize that it is an ohm issue so I googled whether I could solder in a diode or something to make the BC sender match the original gauge and found it can be done with a 5 watt potential meter. The article that I read was all cheby stuff so the question is what ohm and or watt potential meter would I need if this is the issue. the article said they can be bought at the shack for about 3 dollars?
