blazinchuck
- Jul 14, 2005
- 3,319
been getting an annoying belt/pulley squeal every time i crank it up or a quickly change rpm's. so far...I have changed the belt, water pump,AC clutch, water pump pulley, and swapped alternators...with NO FREAKING HELP!
even removed the air inlet tube, the verify the throttle body isnt whistling.
here's what I think I figured out...the BC fan seems heavy and pulls air like a mofo! but its causing the water pump pulley to drag just a hair...making that squeal.
bought a clutch fan hoping to use it, but it doesnt fit(keep in mind, I moved my radiator support forward 1.5" just the width on the radiator, so i could easily fit the bc fan or others)
Right now, I installed a stupid flex fan(came off my old 306 motor). the noise is all gone with this lighter fan, but I see its not gonna come close to keeping the motor cool at all. I always had a 12" elec fan mounted in front for extra cooling(hardly ever runs)
now its running alot more and longer , cuase the flexy aint working 1/2 as good as the fixed blade.
has anyone ran into this issue? I even have a taurus fan assem...but there aint any room for that even with the radiator moved!
