C5TA-6394-A
Located between the trans and the bell, impossible to see when installed. If it's cast iron, and it's 164 tooth, and it is drilled for your Bronco clutch linkage, and if bolts to your Small Block Ford, and your 3 speed bolts to it... then this is it.
