Hey Guys,
Thanks for the comments.
I guess what I don't understand is the need to bench bleed on a bench versus bolted up to the hydroboost unit. By operating the brake pedal the rod moves to operate the master cylinder piston. How much different is that than using a tool to depress the piston. Maybe a difference in travel? If there's no real difference, I'd prefer to bolt it in and do a 'bench bleed" without the hard lines installed. What am I missing?
The reason I'm asking questions is that I want to do it right. If that means a bench bleed off the vehicle... I'll do it. Otherwise, on the vehicle will simplify things.
Thanks,
Jeff
Thanks,
Jeff
