Steve83
That's not a particularly precise surface to use; especially with the coating on the frame....using the face of the "doughnut" at the datum....
That suggests that the problem existed for some time; not just a recent change.The old one I took out was really smashed to hell on the botton side from being pinched...
Looking more-closely at your pic, I see what might be a witness mark from the bracket rotating around its bolt. Is it that, or just some random dirt smudges? Is there any corresponding mark on the other side, or on the bottom? If there is, and you try to adjust it back, I wouldn't use heat - I'd use slow hydraulic pressure, like a bottle jack pushing it. The trick will be giving the jack an anchor on the frame strong enough to push against. So it might be easier to pull against the rear crossmember with BIG chain (the cross-section of 1 link needs to approach the cross-section of that RA bracket where the bending will occur).
Another problem I notice that's almost certainly contributing to the RA frame bushing pinch is the "Bronco lean" you have in the way the RAs are clamped to the axle tube. Yours is maybe only an inch, but every little bit hurts. Assuming the floor is reasonably flat over this distance, and the jack stands are set at the same height, and assuming they're both touching the axle tube surfaces (not on some random lump), the RA tips should touch the floor equally.
If you want everything "right", you should loosen the RA bolts at the axle end, and try to neutralize them around their bushings so the arms are perfectly parallel.
