Bending Stock Radius Arm Brackets
jdowns67
Owner since 2001
Wilmington, NC
During replacement of my radius arm bushings, I discovered that the mounting hole "dougnut" is bent upwards about 4 degrees on one side. I am probably going to replace the whole bracket but has anyone ever had any luck bending back into position? The hole through is 1-3/8" diameter. Was going to try and machine the end of a long bar to this diameter and attempt to tweak back into position since it is not off by much.
Steve83
4° is probably closer than the factory specified when new. It's not a 300mph Bugatti - it's an old 4WD. Just run it. 4° is probably <1/64" at that diameter, so it's not gonna move the bushing or RA enough to measure. I'm surprised you measured 4°.
jdowns67
jdowns67
Owner since 2001
Wilmington, NC
It's actually pretty obvious it has the bushings pinched on the bottom.
Is this by any chance the passenger side?
Been meaning to do the exact same thing to mine, that you’re planning, for the last 40+ years.🙄
spap
I think my 77 pass side is a little more pinched that the driver side I’ll have to look
jdowns67
jdowns67
Owner since 2001
Wilmington, NC
Update: In the original post when I said it was 4 degrees upward, I meant from vertical. From the factory the doughnut is facing downward probable 3 or 4 degrees for a total of around 7 degrees off. The pipe trick didn't work although it seemed like it wanted to work. I am going to try heating up the bracket with a torch to "persuade it" a little more before I go for the replacement option.
When I first saw mine, I thought it was odd that someone could back over something hard enough to bend it forward but not damage it in any other way visible.
Especially when connected to all the rest of the suspension.
That was long before I understood that the factory didn’t exactly take a lot of care and how they welded things together. And on top of that, I also thought that it was possible that they did it on purpose, as a fine-tuning alignment tool!
But when I mentioned it on different forums about 20 years ago, no one else had noted it on theirs. Now we have three of them. Two on the right, one possibly on the left.
Mine is a 71. Yours is a’67 downs?
jdowns67
jdowns67
Owner since 2001
Wilmington, NC
No, mine is a 71 also. It does seem strange that there is no obvious damage anywhere to indicate it was bent in an accident. The reason I am going into all this is because I had an accident a couple months ago where I had to go into a ditch to avoid an accident. There was no body damage or anything but it did knock my alignment out. So in analyzing everything, I really believe I am now finding things that may have been there all along.
I am taking the opportunity to replace all the bushing, finally do an adjustable track bar, Replace the leaf springs in the back with Wild Horses, etc....
Now you’ve got me curious. In what month was your Bronco built?
I can’t remember mine offhand (Nov ‘70 maybe?), but I’ll go check when I have time.
Just curious if there was a short run of frames that were mis-jigged, or if it was done on purpose.
Did yours come with a Dana 30, or a Dana 44 originally?
Thanks for the additional data point! This is getting even more interesting!
jdowns67
jdowns67
Owner since 2001
Wilmington, NC
I'm not seeing it in your pics. Where exactly are you measuring this 4°, and relative to what? What did you use to measure it?
Ya the picture does not do a great job showing really. The pinch of the bushing is kinda what shows. The 4 degrees is off vertical. The other side is around -3 degrees, so you could say it is about a total of 7 degrees off from the driver side. I am using a digital level that gives degrees and using the face of the "doughnut" at the datum. The reason it bothers my is because when the suspension is in it's relaxed state, the bushing is very pinched. The old one I took out was really smashed to hell on the botton side from being pinched as the suspension moves up and down. Just by the fact that I already have 2-1/2" suspension lift which angles the radius arms further down than stck and then the bracket being off, really makes that bushing in a bind. Bottom line is I just want to correct it before I put things back together with all new bushings.
SLOWnEASY
San Diego, Ca.
My 77 is not pinched on either side.
One thing I see that is curious on your Bronco appears to have two different style mounting points to the frame. The passenger side looks like what I would assume something built in the early 70's looked like. The drivers side with the the little concave points in the front and the top and the generally rounded off corners makes me think the mount was possibly a future replacement.
SLOWnEASY
San Diego, Ca.
I can't tell if your passenger side bracket is welded on, but the drivers side definitely does not look welded. If not welded and it's just that single bolt I would think you can loosen the bolt and put a small spacer to fill the gap to straighten things out. But going back and reading your posts about trying to heat it and using a big pry bar makes me think that it's definitely welded. But then again why is the drivers side not welded? Or am I completely wrong and just looking at the wrong parts?
