Best chemical to remove dirt/grime from t-case/diffs/etc?
duffymahoney
Have you guys seen the dry ice blasting? It's pretty cool how clean it gets everything.
Johnnyb
Flagstaff
I've been scrubbing away on mine with mineral spirits in a spray bottle and a couple of brushes. Slow going but it works. I may try some of the purple stuff to finish it up before paint.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Purple Power is not good for Aluminum either. It will dull it and leave a white film. That said, it's the best thing I've found to take off grease. Pressure washer after a good soak in PP
Tim
Thanks, I never seen that result. A Hotsi (HOT water pressure washer) also works great.
duffymahoney
I wash Aluminum with PP all the time, and I've never seen any reaction, other than shiny Aluminum.
PP eats aluminum, even simple green does. Simple green makes an aluminum safe version for airplanes. I use it when cleaning carbs for rebuild or aluminum wheels.
J
Jc.av8r
Did the first round of scrubbing a week or so ago. Before and after of the transfer case is pretty satisfying. I forgot to take pics of the rear diff but I'll snap one in the next day or two. That area is a a bit more involved.
I used a combination of simple green, water, paint scraper, wire brush and wire wheel. The paint scraper and the wire brush seemed to be the most effective.
I ran out of time, but plan on getting under there again soon to try and get more off.
And yes, it obviously feels much better driving down the road knowing she's so much better on the under side 😁
bigmuddy
Marthasville Missouri
BRAKLEEN is TOXIC...
"Tetrachloroethylene's long-term effects as a carcinogen and its link to Parkinson's disease..."
Look it up everybody.
MOTORTREND quote below:
"...While PERC is an extremely capable industrial cleaner, it’s very bad for you. So bad the United States Environmental Protection Agency (EPA) classifies it as “likely to be carcinogenic in humans by all routes of exposure.”
I have 3 friends now, 2/3 were auto techs and used Brakleen regularly and the 3 of them all suffer from Parkinsons now.
Welders- remember to NEVER use Chorinated Brakleen prior to welding.
This from Popular Science. "Chlorinated Brakleen is even more dangerous for welders. When heated to high temperatures, the cleaner can release toxic gases like hydrogen chloride and phosgene, according to a Popular Science article from 2009'
I remember when this came out in many magazines on the chlorinated brakleen as its popular with a lot of welders wanting to clean up old greasy stuff before welding. But if you are a puddle of it, it will turn in the Phosgene and smoke your lungs, really bad bad shit.
nvrstuk
PNW
Same here bigmuddy- they implied the non-chlorinated was better for us and it's NOT!!
Title speaks for itself. I'd like to spend some time underneath our Bronco to clean the grime up off of the transfer case, oil pan, and front/rear diff covers.
What's everyone's preferred chemicals and tools to do so with the least amount of elbow grease?
Hello sir, this is completely unrelated but I I was on some other forums in regards to BMWs and someone mentioned you to me. I think I might be buying your old e39 m5 and have a couple questions for you!!! Hopefully this reaches you.
