Best Column replacement for an 88
MonsterBIlly
MonsterBIlly
Sorry guys. I hit send to quick on that before I was done using voice to text.
Does anybody know where the source of replacement steering column for a nineteen eighty eight. Or can I use an f one fifty column in its place.
Or is it best just to use an aftermarket column.
LittleBeefy
Huge Brakes - www.hugebrakes.com
Auto column will work on a manual but not the other way around. Drilling it out to rekey it is a PITA so get one with a key if you can. Tilt and non tilt use different turn signal switches so if you already have a working switch try to find the model of column that matches what you already have. Holllanderparts.com is your friend in this situation.
