I have the WH's Ididit direct replacement column in my 68. It is column shift for my 4R70W...
For the rest viewing this, in his '68 it would have been a little more work to wire it up, but since he had an aftermarket harness anyway, the point was moot.
But the wiring is really the only reason we don't list them for 73 and earlier models anyway. If you notice that we only start at '74, that's because of the later turn signal switch and connector.
The gear shift indicator, which you have to install (by drilling two small holes), is not lighted.
Yeah, lighted like stock would be cool. Probably a way to do it, but I've never looked into it.
I'm assuming you do have the OD model indicator Doug? (Yeah, I should know since I sold it to you, but I forget...%)) Did you try the stick-on type?
Or was it a stick on and you still had to drill for some reason?
The rotation from Park to 1st gear is not true. By that I mean when you install the GM based indicator, you set it up so neutral is in the center. Travel of the pointer, which is glued down to the moving portion of the column, can be a little more/a little less in each direction.
I thought that's what we used too?
http://www.wildhorses4x4.com/product/IDIDIT_Tilt_Column_Indicator_Acrylic_AOD
Or is the range for an AOD not the same as the 4R70? Thought they were based of the same trans family, but maybe not.
Being 6' 4", when I drop the gear selector down into 1st gear, there is not a lot of room for my right leg, with the T-shifter and Tuffy center console.
I wonder if there is a way to shorten the throw with geometry? Modifying the location, angle and length of the rod and lever maybe?
Anyone ever messed with that kind of thing? I hate long travel column shifters myself, for the same reasons you're stating.
And either I've shrunk (very possible) or you're taller than 6' 4"!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I think Roger Miller had a song about your brother...
