Run a stoc D44 front cover. They are the thickest steel. Aftermarket chrome is too thin and bends. Fancy aluminium likes to crack.
Nothing in the back, but I have thought about a Currie housing with the shaved bottom.
What are you trying to accomplish?
If you are hitting rocks hard enough to damage the axle, no bolt on protection will do anything for you.
If you are trying to play PJ and see how much air you get at the dunes, find a fab shop and have them build you a good cage first, then truss the axles second. Weld on is the only way it will be any good. And you will still have the weak point of the ball joints and knuckles. Aftermarket thick wall axle housing is the only resonable option for the rear.
