Remove the third member, pound the studs out, insert new ones from the back, pull them in using washers and a nut or put your third member back in and use it instead of washers.
RTV will seal the studs when you reinstall the 3rd member, if you use RTV. If you use a gasket without RTV, you must use copper washers under the nuts to seal the studs.
