CopperRanger
- Sep 26, 2007
- 1,795
I have mine out the sides behind the rear tires, no issues with fumes
I went back and read and haven't said best that I can tell,are you going with duels or single exhaust?
If your going to wheel your Bronco, then a turn down tailpipe should be avoided because of the dust it creates, as TN1776 has mentioned. Exiting in front of the rear tire, behind the rear tire, out back, I've smashed them all. I run it through the rear quarter panel now. I still hit it sometimes but the tip is easily replaced. I wasn't surprised that it would still get hit there, the rear quarters take a lot of abuse, especially on the wife's side of the Bronco.
Mark
Mark
Nice! Do you have any problems with the exhaust heating up the paint where the tip comes out?
With my 1" bodylift I ran mine over the frame and the rocker has been replaced with a tube slider that the exhaust exits through. If I damage it there, I probably have bigger things to worry about, like a driveshaft.
It's nice and mellow, has a good low rumble from the Thrush Muff.
Jim W.
