Best performance/value hydroboost system?
quic
gr8scott
I went with this bracket made by CB member catfan. No cutting, threading any rods.
quic
these are madfab sets... astro hydroboost and 77 corvette master cylinder. the rest i fabricated
Did you use an adjustable proportioning valve on these? or did you use the factory one?
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
Astro booster and MC, S-10 reservoir, custom plate and rod in stock position.
Madgyver
Bronco Madman
Yes I have an adjustable proportioning valve accessible under the driver's side inner fenderwell.
quic
here are some pics, the red things are 1/8 glass shims that slide in smoothly
quic
Are shims used for fitment so you can cut rod to correct length?
Yes, the directions say to cut the rod so that the two surfaces meet, I have to cut another 1/8 to make that happen.
I just stuck the shims in to hold the master cylinder parallel for the photo
