best steering swap/upgrade
bobzilla
Riverside, ca
My 68 has some steering issues. It has a 2.5WH lift with a 1" body lift and 33x10.50 bfg km2s. My truck has zero return to center after turning and my power steering seems to decide on its own when it wants to work. Ive gone through all the basic bushing stuff and loose part's check and i think i have got most of those problems taken care of, it tracks straight and true with no death wobble. A few things i need to address still are new adjustable drag link, steering stabilizer, and i think i need to get some new c bushings. Im not sure what degree bushings i got with my kit but im assuming i have the 4 degree and i hope 7 degree bushings will help. All that being said my steering box leaks and my power steering pump leaks. What would be my best (ie cheapest) route to get this thing driving better/safer. Should I rebuild my box to a 4x4x2 and buy a used saginaw pump, or are there complete swaps from another vehicle i can use. I dont care about holes in the frame i dont mind drilling or welding if it will save some $. I would like to upgrade to hydro boost in the future so a dual return pump would be nice.
Chief Master Sergeant
Retired U.S. Air Force
I would just have someone rebuild your box or you could reseal it yourself. Then just upgrade to a Saginaw pump. West Texas Off-road or PSC seem to be the most popular rebuild options.
Rox Crusher
From what you describe it seems the system might run low on fluid which is contributing to the inconsistant functionality of the power steering.
As already recommended, rebuild the box and upgrade to a dual return sag pump.
If you aren't suffering from bump steer or otherwise darty steering, you probably won't benefit by adding a steering dampner / stabilizer.
Meanwhile, I would highly recommend taking it to your local Firestone service shop (hopefully there is one nearby) and sign up for their lifetime alignment service. Usually about 150 clams. In additions to properly adjusting it, they will give you all the steering geometry measurements so you can decide what else might need to be done as far as parts, etc.
good luck
SteveL
Huge chevy guy
Hawthorne ca
If you upgrade build yourself a 4x4x2 box. Go to napa and get a dual return saginaw pump. They aren't that much. No need for a stabilizer with that small of a tire. It might make it worse. As far as wheel not returning is your box centered? Thats where the adjustable drag link will come in. That should help if the other parts are good. Check in with paul/wh for correct c-bushings.
B
bobzilla
Riverside, ca
Thanks for the replies. With the 4x4x2 box rebuild is that something i can do on my work bench with standard tools or do i need something special? Will doing this upgrade allow me to change the ratio as well?
ep67bro
Bronco Junky
Easton, MD
I would rebuild the stock box and upgrade to the Saginaw pump. The stock box is not hard to rebuild, and the Saginaw pump is a great up grade. No leaks after I did mine and drives straight no issues at all. I run 33s and had 35s on it for a while still no issues. Changing to the 4x4x2 box will cost you a little more coin than just rebuilding the stock box. You should upgrade to the Saginaw pump no matter what box you use.
surfer-b
Steering not returning to center after a turn is caused by lack of caster. You can try the 7* bushings but I doubt they will be enough for it to return the way it should. Go ahead and rebuild the box, add the saggy pump and the adjustable drag link, drive it and see what its doing, if no better, and I doubt it will be, you will need to add some caster. There are a few ways of doing it however the way I recommend is to leave the 4* bushings in or even go to the 2*, whichever gets the front pinion angle correct, go get the caster/camber #'s on the front axle, then grind and rotate the yokes to get ~ 8* pos. caster. Yes its a little bit of work but you will be glad you did it.
