Billit fuel door
mnido
I would like to do a billit fuel door with the filler cap inset. Has anyone done this with the fenders cut ? If so what is the brand name, my concern is clearance, I realize I will have to trim the flares. Thanks
Tito
CB Fire Starter
Bakersfield, CA
I did, I used a motorcycle gas tank. It was a pain (still is) to get the filler to work right. The aero cap is the way to go. The modern vehicle billet doors are too big (look and fit) for the Bronco cut quarters. Search aero fuel door and you should find info. The motorcycle method I think is a little cleaner look than the aero but not nearly as easy.
mnido
mnido
I don't mind the difficult install, my concern is what kind of issue are you having with the filler ? Is it because you had to trim the filler tube (shorten ) ? Where diid you purchase yours ?
Tito
CB Fire Starter
Bakersfield, CA
yup! I cut the neck down and welded it to the gas door that I inistalled but it was hard to get the angle right and since it is soooooo tight in that filler section I am having trouble sealing the rubber tube to the filler neck that is left. My filler is at a bad angle and the rubber filler just doesnt want to fit right. I need to cut the vent off and run it separately to fix it. I know what I need to do to fix it but I just havent done it yet. It really was an easy mod I just was inexperienced. I would definitely do it again...and use another motorcycle tank too.
mnido
mnido
I like the look of yours ! Did you have to get a salvaged tank and cut the part out ?
mnido
mnido
Hot Wheels do you have any issues when filling up with gas other than the price ?
HotWheels
Twilight Zone
Nope. I love the mod. I am adding a vent to the vapor reurn tube. I am also adding a water/fuel separator on the cross-frame infront of the gas tank.
But im in the process of installing a/c right now.
Frankenhorse
Smyrna,TN
I didn't think you Oregonians were aloud to pump your own gas.?:?
Frankenhorse
Smyrna,TN
I always got the stink eye from them every time I went to Wa. I would cross the Ca border and just hop out and start filling. I always seem to forget.
I like the Aero fuel doors. I may have to tackle that at some point.
76MaBronco
Massachusetts
You can't pump your own gas in CA???? What's up with that?
bax
Old Member
good one bax got pics?
These fit and are just the right size. No need to make the stock hole bigger and they are not too big around so they pull up pretty good to the body.
I got a front bumper put on too.
Bax
